Hello Guys,
I’m implementing Software Encryption using Commvault built-in Key Management Server. May I know, how we can check the performance on the job running with encryption enabled?
Thanks.
View originalHello Guys,
Thanks.
View originalWe have a great blog article here that covers performance troubleshooting, though the method for you to check is the same:
Let me know if that covers your needs!
We do monitor the performance of the Backup even using Software encryption by default. We monitor and display throughput in the normal Job Details. We also log more detailed performance statistics of the jobs. Is there a specific aspect you are looking to gather?
Hi
Hi
