MS SQL Granular restore - Huge Database Problems with the mount
  • 21 July 2021
  • 121 views
Userlevel 1
Badge +1
Hi, we want to Test a Table Restore with a database size is about 1TB.
With smaller Database it works.
But with the 1 TB DB, the restore hangs. Could this be a Problem with Diskspace for the 3DFS on our Windows Media Server ?
Peter Rupp
Best answer by Mike Struening RETIRED 21 July 2021, 16:23
Userlevel 1
Badge +4
Hi Peter,
Is this restore coming from block-level or snap backup?
How much space is on the volume hosting the Job Results directory on the destination client?
This will be getting used as a cache for blocks being restored here as part of the block-level browse and if this is low on space we can see performance issues occurring.
David
Userlevel 1
Badge +1
Hi @ddwyer ,
it is a block-level backup.
You mean the JobResults under C:\Program Files\Commvault\ContentStore\iDataAgent\JobResults ?
There is on the destination client about 150GB free.
I have modified the 3DFS Cache root directory on the client.
How can i move the JobResults Directory to another Disk ?!
Regards
Peter
Hey @Peter Rupp , you can move the folder via these instructions:
https://documentation.commvault.com/11.21/expert/6588_changing_path_of_job_results_directory.html
Let me know if that helps!
