last post link bellow
after validated that my Prod and standby commserve are functionnal.
I have tried to execute the test failover from the process manager of prod commserve cs01
All seems to be good but after 30 minutes it stuck at :
Sending the request to make node [cs02-SQL] active...
Checking PreRequisites for test failover operation... Done
Confirming no CommServe SQL LiveSync jobs are running... Done
Disable restore schedule for node [cs02-SQL]... Done
Perform last sync up before failover... Done
Restoring database(s) with recovery option... Done
Executing recovery tool in maintenance mode for test failover... Done
Comparing the database and binaries version... Done
Disabling read only CommServe mode if enabled... Done
Enabling Test CommServe mode... Done
Doing name change if required... Done
Revoke CommServe certificate... Done
Delete firewall configuration file... Done
Update firewall settings... Done
Enabling and starting all the services... Done
Update test node information in the config file... Done
Enable auto start of services...
Services were started on the cs02 Commserve.
is there anything to do ?
I had to restart the 2 commserves because no way to cancel thaht after 30 mn.
and now here is what I have it is in Test failback mode :(
Thanks !
Best answer by Leo E
