Thanks Bill for detailed documentation. This helped me during setting up NFS for teradata backup purposes.
I see performance for the jobs written on NFS is not same as other jobs using same disk library.
NFS jobs are running with average throughput of 100GB/hr while other agent jobs to same disk library is in TB/hr.
Ran CVperformance check on disk cache and that is also much better (throughput in TB/hr)
Anything to check further. I have logged support case but any advice is appreciated.
