Hello community,
I am testing a CLI (qoperation) restore script to restore a random file from clientA to clientB, but it is not working. The script is getting the following error on the qoperation cmd for the restore XML file:
Out of place restore. User [{clientB}_localadmin__] must have [Out-of-Place Recover] capability for the source and [In Place Recover] capability at the destination.
Anyone have any idea why I’d get this message?
The script is being executed on clientB, but I also get same error running it directly on clientA, the host where the source file lives.
To create the restore script, I used the java console to select clientA/subclient and a specific backup date, then selected a sample file to restore and filled in the restore dialog as a re-directed restore to clientB - then saved the restore script (save-as-script). I can certainly restore the file if I were to just let the restore run directly from the restore dialog, but for some reason the save-as script is not able to run the XML file. Seems bizzare, and I’ve not found any setting that controls out-of-place restores, or any BOL page that might explain this. Maybe I’ve not looked hard enough, but if there is such a setting, why would it be allowed through the console interfaces but not via the ‘Q’ commands?
Thanks in advance for any feedback.
/steve
Best answer by S Green
