Please help me to understand commvault media agent with deduplication
Hi
i need to understand media agent Deduplication concept .
this guide covers every concept regarding deduplication and is a great place to start:
https://documentation.commvault.com/11.24/expert/12411_deduplication_building_block_guide.html
This guide will describe how to size your MAs depending on your use case:
Let me know if you have any questions this doesn’t cover.
Also Brief on Parallel Data Stream Transfers
Hardware Specifications for Deduplication Mode (commvault.com)
Hi
Back End for Disk Storage tells you what size (Back-end) the Media Agent(s) will be Capable of, depending on the configuration. - Example below:
3x Large MA’s with 1DDB = 450TiB Back-end Storage
3x Large MA with 2 DDB Disks = 900TiB Back-end Storage
For Disk Layout, This tells you the config required for the MA:
For each Large MA you need 400GB OS Disk, 1.2TB SSD DDB Disk and a 1TB SSD Index Disk:
Michael
Back end storage size = Azure blob storage capacity or HP store once Storage capacity
3x Large MA’s with 1DDB = 450TiB Back-end Storage -- It means this configuration can manage only 450TiB Azure blob storage?
Hi
Back-end storage size (disk) would be the Capacity for the Disk Based Library, yes.
Are you deploying on-prem or in cloud (Azure) or both? - For Azure we have a Cloud Architecture Guide here: https://documentation.commvault.com/commvault/v11/others/pdf/public-cloud-architecture-guide-for-microsoft-azure11-19.pdf
Since Cloud Storage uses a Higher Deduplication Block Size (512kb) the calculations here are different, for a Cloud MA:
Michael
Backup server : On premise
MA : Azure cloud
Backup types : Oracle DB and Oracle Archive backups:
Backup end Storage : Azure blob storage(hot and cool)
i need to deploy Media agents to manage 500 to 700TB cloud work loads,
what can be best media agent sizing. please provide your input
Initially i am starting with 3 Large Media agents with 8Vcpu and 64 GB RAM, 1 TB SSD Index cache & 1 TB DDB Storage.
