Hi Team,
We are looking at a requirement to deploy an RHEV-compatible backup configuration on behalf of our customer.
Although I have implemented plenty of ESX configs, this will be the first RHEV, so I have a few questions.
1 - Ports required to access the RHEV Manager host .
Which ones do we need to open up?
I can’t see anywhere in available documentation for any ports that I may need to open, but I’m thinking that there should be. I remember in ESX that 903 (or is it 902, ha!) needs to be open so I would expect this to be similar for RHEV.
2- The VSA Proxy - Does this introduce another Media Agent for us to manage?
So if, or when we install the VSA client onto our RHEV vm, am I correct in assuming that will also install the Media Agent component? And if it does, we obviously have another server to manager and maintain patch levels etc etc.
3 - RHEL 7.7
The vm’s are running at RHEL 7.7 which I think is XFS filesystem by default.
What do we do if we need a granular restoration of a file?
Do we need a new FREL, or can we use an existing?
Alternatively, can we install restore-only agents on each vm and avoid the need for FREL?
4 - Any other gotcha’s I need to know about?
May as well ask whilst I’m here!
Thanks everyone ….
Best answer by MichaelCapon
