Hello guys,
is there a method, that allows me to rename the CommServe’s client name ?
in previous Version (<SP16), I was able to do this during a DR Recovery. But this option seems to be removed from CSRecoveryAssistent.
I now can modify the displayName instead, but most of the reports, as well as the MetricsServer, are still pointing to the clientName, which can be slightly confusing.
I moved the CommServe to a different Domain, and the ClientName was matching the HostName, which is the FQDN of the CommServe.
I’m using currently using FR22 for this environment.
any hints wellcome
Klaus
Best answer by Sean Crifasi
