When restoring DR backup to another commvault server the restore fails with error:
Execution of process [CommServeDR.exe] exited with code [20]
Any help is appreciated.
View originalWhen restoring DR backup to another commvault server the restore fails with error:
View originalHi
To confirm, you are restoring the Commserve database to another Commserve?
Can you share the excerpts from the CommserveDR log files? Few possible things happening, though the log files will give us a better picture.
Yes restoring. I rebooted the destination server and the restore went through.
Thanks for the reply.
Following on the above..i have successfully restored the database on another server. This server has it’s own tape library. After restoring the database the existing media agent and library was replaced by the one from restored database.
Questions:
Please advise.
Essentially, you restored the original database, so the CS now only sees what it thinks it had access to previously.
To answer down the line:
