Scality ARTESCA as S3 Compatible Backup Storage
  • 25 November 2021
  • 424 views
Badge
Looking into CommVault supported S3 Compatible Storage Vendors I can see Scality RING but not Scality ARTESCA even though both are S3 Compatible storages.
Would that mean Scality ARTESCA is not validated for use as Commvault S3 compatible backup target storage?
Best answer by thirstler 11 February 2022, 02:20
Userlevel 5
Badge +9
Hi @vku
Unfortunately ARTESCA does not appear to be certified yet.
If you’ve engaged Scality, they can request it be verified and certified through the link below;
https://documentation.commvault.com/11.24/expert/9242_verifying_cloud_storage_product_compatibility_with_commvault.html
Cheers,
Jase
Badge +1
Hi @vku - Scality Artesca was certified and added as a supported backup target in January.
https://www.commvault.com/supported-technologies
Enjoy!
-Jason
Thanks for the update!  I moved the Best Answer accordingly to your reply, @thirstler !
