SQL Live sync operation converted to Full restore
Badge +2
I have configured sql live sync, and there is a schedule configured to be performed after the backup job completes,
Everything is going fine but suddenly the sync operation converted to full restore without any change in the source server also there is no change occurred in destination side so i am asking about this behavior as its not logic to change to full restore with out any change !
Commserve,Sql clients & MA version is 11.23..
Badge +14
Hi @Nezar
Thank you for the question.
There are a few situations where a full restore may be performed over anon-full restore.
Automatic Conversion of Non-Full Backups into Full Backups
A non-full backup is automatically converted to a full backup in the following situations:
  • First backup operation of a subclient.
  • Backup operation run after promoting a secondary storage policy copy that is not synchronized with a primary copy for all the subclients of a storage policy.
  • Backup operation run after a backup job of the recent backup cycle was pruned or disabled from a primary copy.
  • First backup operation run after switching from a IntelliSnap backup to a traditional backup or vice-versa.
  • First backup operation run after a CommCell migration operation.
  • Backup operation run on databases after the following restore jobs were run on those databases:
    • Point in time restore
    • Transaction mark restore
    • Partial or Piecemeal restore
  • Backup operation run on a database after switching the recovery model for that database from simple to either full or bulk-logged.
  • Transaction log backup is converted to a full backup if a broken chain was detected during the previous transaction log backup operation.
  • Transaction log backup is converted to a full backup for a database that already performed the transaction log backup before it received a suspension request.
Please also check the SQL Livesync schedule. Potentially the schedule may be configured to perform a full backup once per day/week and log backups the rest of the time. The Livesync operation will likely be configured simply to restore the most recent backup.
Stuart
Badge +2
Thanks @Stuart Painter , My situation is TL log backup was taken normally from the source DB and only Live Sync operation changed to full DB restore whiteout in change in source and even destination.
Badge +2
@Stuart Painter Continue* Regarding the Full backup its already configured to be once weekly and TL is configured every 15 Min and this conversion occurred before the next full backup schedule comes.
Badge +14
Hi @Nezar
Maybe one of the other conditions occurred to cause an expected TLog backup to be converted to a full?
Stuart
Badge +2
Hi @Stuart Painter
Actually the TL backup taken normally and didn't convert to Full and only live sync operation changed to Full restore and its configured to run after the TL backup completed but i have a question here , Does the live sync changed to full restore if we run it immediately and it is only available upon the schedule configured or not ? and what happened if the Full backup the TL bk depend on it expired ?
Nezar Hamed.
Userlevel 2
Badge +2
Hello @Nezar
The live sync will check the source and destination as well as query the msdb for backup history. If it detects a broken chain or similar issue it will automatically restore the full back to reset the chain. Once that is complete it should restore just tlog backups indefinitely. It is similar if it detects that the destination database does not exist it will go back to the latest full backup of the source and apply that with all recent tlog backups. There must always be at least one valid full backup available. Fulls backups can continue to run on the source and live sync will continue and skip that full and just apply the logs.
Badge
@Nezar , Thanks for posting your question here. I went through the above discussion and understand the behavior you have seen. Live Sync Restore operation detected broken chain and started the restore from the scratch. Please correct me if misunderstood.
Before I conclude the RCA here, I would like to get configuration for live sync. Can you please shed some light on your configuration? Whether it is configured from 2nd copy? etc. Screenshots can help a lot here. TIA.
Badge +2
@Sadham Hassan No broken chain detected on the production DB and also Destination DB , and without any reason the Live sync operation which is configured to be run ever 15 min, change to full restore operation,,
Badge +19
@Nezar , might be best to open a support case and have them track down the reason.
Once you do, please share the case number here so I can track it.
Badge +2
@Mike Struening @Sadham Hassan @Scott Reynolds @Stuart Painter
Please find the conversion from the below logs and if anyone can support :-
3860  98    10/13 13:02:17 273881 ProxyOptionsParser::ProxyOptionsParser(54): -Debug-: Command line: SQLBackup.exe -p 273881 -j 273881 -jt 273881:3:1:0:59729 -cn db-replica-serv -vm Instance001 RESTORE
3860  98    10/13 13:02:17 273881 main(162): -Debug-: === Job Id [273881] =============
3860  98    10/13 13:02:18 273881 Cvcl::init() - CVCL: Running in FIPS Mode
3860  98    10/13 13:02:18 273881 CSQLCommon::getServerTypeForRestore(2663): -Debug-:  Job ID [273881]
3860  98    10/13 13:02:18 273881 CSQLCommon::getServerTypeForRestore(2666): -Debug-:  Instance ID [443]
3860  98    10/13 13:02:18 273881 isCCSDbEnabled() - Use CCSDb Enabled [0] IsCloudLaptop [0] IsFSCoreLaptop [0]
3860  98    10/13 13:02:18 273881 CSQLCommon::getServerTypeForRestore(2675): -Debug-: Server type : [DataBase Engine]
3860  98    10/13 13:02:18 273881 main(237): -Debug-: The SERVER TYPE OF THE SQL INSTANCE IS = DataBase Engine
3860  98    10/13 13:02:18 273881 main() - Running CSQLRestore.
3860  98    10/13 13:02:18 273881 Init() - Initializing job control [token=No Token,cn=db-replica-serv], serverName [commvault-sizing], ControlFlag [1], Job Id [273881]
3860  98    10/13 13:02:18 273881 CVJobCtrlLog::registerProcess(): successfully created file [C:\Program Files\Commvault\ContentStore\Base\JobControl\3.860]
3860  98    10/13 13:02:18 273881 JOBRESCACHEDIR: job 273881 creating 'C:\Program Files\Commvault\ContentStore\iDataAgent\JobResults\CV_JobResults\2\0\273881'
3860  98    10/13 13:02:18 273881 CSQLCommon::initializeRestore() - Time taken to register the job with the jobmanager = 0.074283
3860  98    10/13 13:02:18 273881 CSQLCommon::initializeRestore() - JobManager initialized.
3860  98    10/13 13:02:18 273881 CSQLCommon::initializeRestore() - Restore TaskId = 273881
3860  98    10/13 13:02:18 273881 CSQLCommon::initializeRestore(1653): -Debug-: VDI Timeout retry count is [3].
3860  98    10/13 13:02:18 273881 CSQLRestoreBase::startRestore() - !!!! STARTING Restore JobId [273881] Task Id [273881]!!!!
3860  98    10/13 13:02:18 273881 CSQLRestoreBase::startRestore(475): -Debug-: Restore operation for combined AuxCopy is [Enabled].
3860  98    10/13 13:02:18 273881 CSQLRestoreBase::startRestore(484): -Debug-: SQLSERVERRSTOPTION_CLONE_ENV [false]
3860  98    10/13 13:02:18 273881 CSQLRestoreBase::InitializeLiveSyncJob(9964): -Debug-: This is a live sync restore job.
3860  98    10/13 13:02:18 273881 CSQLRestoreBase::InitializeLiveSyncJob(9980): -Debug-: Found restore source [DBA] with replication id [11].
3860  98    10/13 13:02:18 273881 CSQLRestoreBase::InitializeLiveSyncJob(10035): -Debug-: Adding replication site info for replication id [11] and database [DBA] in the cache.
3860  98    10/13 13:02:18 273881 CSQLRestoreBase::getUpdateIntervalSecs() - GUI progress updates will be sent every [300] secs
3860  98    10/13 13:02:18 273881 CSQLRestoreBase::startRestore(518): -Debug-: Restore optimization is [Enabled].
3860  98    10/13 13:02:18 273881 CSQLRestoreBase::startRestore(536): -Debug-: Append RESTART option via global param/registry key, for restore query: [NO]
3860  98    10/13 13:02:18 273881 CSQLRestoreBase::getRestoreOptions(7396): -Debug-: Using [300] as VDI TIMEOUT
3860  98    10/13 13:02:18 273881 CSQLCommon::cvImpersonateUser() - Username = [administrator], Domain = [Vacnew]
3860  98    10/13 13:02:18 273881 CSQLCommon::cvImpersonateUser(700): -Warn--: Failed to do Interactive Logon as user [administrator], domain [Vacnew], ErrorCode [1326], ErrorDescription [The user name or password is incorrect.
]. Trying to logon as a batch job now.
3860  98    10/13 13:02:18 273881 CVImpersonateLoggedOnUser() - caching user sid [S-1-5-21-2209472827-3193002982-964322-500] for optimizing subsequent impersonate operations for this user
3860  98    10/13 13:02:18 273881 CSQLCommon::getServiceStatus() - Opening Service : [MSSQLSERVER]
3860  98    10/13 13:02:18 273881 CSQLCommon::isSqlServerRunning() - SQL Service status for [MSSQLSERVER] [4]
3860  98    10/13 13:02:18 273881 CsqlDMO::InitializeCOM() - <COM> - Already initialized.
3860  1     10/13 13:02:18 273881  ManagedLogger::SetCLRThreadPoolMaxThreads - CLR ThreadPool's maxWorkerThreads = [32767], maxIOThreads = [1000], PID [3860], ProcessName = [SQLBackup].
3860  1     10/13 13:02:18 273881  ManagedLogger::SetCLRThreadPoolMaxThreads - Setting CLR ThreadPool's maxWorkerThreads = [1000], maxIOThreads = [1000] PID = [3860], ProcessName = [SQLBackup].
3860  98    10/13 13:02:19 273881 CsqlDMO::InitializeCOM() - <COM> - Already initialized.
3860  98    10/13 13:02:20 273881 CsqlDMO::getInstanceMajorVersion(3194): -Debug-: Server [DB-REPLICA-SERV]: Major Version : [15].
3860  98    10/13 13:02:20 273881 CsqlDMO::InitializeCOM() - <COM> - Already initialized.
3860  98    10/13 13:02:22 273881 CsqlDMO::InitializeCOM() - <COM> - Already initialized.
3860  98    10/13 13:02:23 273881 CsqlDMO::getInstanceMajorVersion(3194): -Debug-: Server [DB-REPLICA-SERV]: Major Version : [15].
3860  98    10/13 13:02:23 273881 CsqlDMO::isSqlInstanceClustered(1604): -Debug-: Instance Name (1) (MSSQLSERVER).
3860  98    10/13 13:02:23 273881 CSQLRestoreBase::getRestoreOptions(7682): -Debug-: Got restoreOptions. Destination Instance is [DB-REPLICA-SERV]
3860  98    10/13 13:02:23 273881 CSQLRestoreBase::modifyRestoreOptions() - Set OVERWRITE option for restore options when Live Sync restore is enabled
3860  98    10/13 13:02:23 273881 CSQLRestoreBase::modifyRestoreOptions() - Set DROPDBCONNECTIONS option for restore options when Live Sync restore is enabled
3860  98    10/13 13:02:23 273881 CSQLRestoreBase::restore70(6584): -Debug-: Time taken to get restore options from CS = 5.076528.
3860  98    10/13 13:02:23 273881 CSQLRestoreBase::restore70(6597): -Debug-: Number of databases to restore [1].
3860  98    10/13 13:02:23 273881 CsqlDMO::InitializeCOM() - <COM> - Already initialized.
3860  98    10/13 13:02:24 273881 CSQLRestoreBase::GetLastRestorePointForLiveSync(7845): -Debug-: Database [DBA] last restore info [<SQLiDA_DBLastRestoreInfo lastLSN="30767002188956200001" restoreType="L" databaseBackupLSN="29702000169282200372" backupSetId="1114" checkpointLSN="30767002126826600001" timeZone="8" backupFinishDate="1634122047" firstLSN="30767000885919200001" />].
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3463): -Debug-: AFiles to restore for db [DBA]:
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3476): -Debug-: Conversion happened. Restoring lastest cycle. ==> 30762000636382200001
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3501): -Info--:     BackupType[L], FirstLSN[30767000885919200001], LastLSN[30767002188956200001], StartTime[1634121915], EndTime[1634122031]:
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [996010], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [996011], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [996013], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [996015], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [996016], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [996017], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [996018], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [996019], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3501): -Info--:     BackupType[L], FirstLSN[30766001749818200001], LastLSN[30767000885919200001], StartTime[1634121013], EndTime[1634121120]:
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995999], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [996000], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [996001], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [996003], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [996005], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [996006], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [996007], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [996008], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3501): -Info--:     BackupType[L], FirstLSN[30766000428738800001], LastLSN[30766001749818200001], StartTime[1634120114], EndTime[1634120249]:
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995989], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995990], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995991], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995992], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995994], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995996], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995997], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995998], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3501): -Info--:     BackupType[L], FirstLSN[30765001116830100001], LastLSN[30766000428738800001], StartTime[1634119213], EndTime[1634119329]:
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995969], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995972], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995974], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995979], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995982], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995984], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995986], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995988], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3501): -Info--:     BackupType[L], FirstLSN[30764001506879500001], LastLSN[30765001116830100001], StartTime[1634118311], EndTime[1634118430]:
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995960], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995961], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995962], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995963], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995964], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995965], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995966], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995967], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3501): -Info--:     BackupType[L], FirstLSN[30764000162922000001], LastLSN[30764001506879500001], StartTime[1634117411], EndTime[1634117510]:
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995948], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995949], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995950], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995951], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995953], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995955], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995956], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995957], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3501): -Info--:     BackupType[L], FirstLSN[30763000510962200001], LastLSN[30764000162922000001], StartTime[1634116511], EndTime[1634116617]:
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995938], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995939], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995940], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995942], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995943], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995945], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995946], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995947], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3501): -Info--:     BackupType[L], FirstLSN[30762000540126500001], LastLSN[30763000510962200001], StartTime[1634115611], EndTime[1634115785]:
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995929], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995930], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995931], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995932], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995933], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995934], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995935], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995936], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3501): -Info--:     BackupType[I], FirstLSN[30762000428027800001], LastLSN[30762000636382200001], StartTime[1634112097], EndTime[1634114916]:
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995882], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995883], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995884], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995885], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995886], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [995887], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3501): -Info--:     BackupType[D], FirstLSN[29702000164476600001], LastLSN[29704000269034700001], StartTime[1633644138], EndTime[1633654929]:
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [981543], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [981547], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [981550], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [981551], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [981553], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLClientDll::getAfilesForDBForLiveSync(3513): -Info--:       AFileId [981555], CommcellId [2], Offset [0]
3860  98    10/13 13:02:25 273881 CSQLDumpRestore::GetDatabases(217): -Debug-: GetRestoreInfo(DBA)
3860  98    10/13 13:02:25 273881 CsqlDMO::InitializeCOM() - <COM> - Already initialized.
Badge
@Nezar Logs shown here are from client. It would be helpful if we can create the support case.
Badge +2
Yes ,@Sadham Hassan m You are right but currently I couldn't be able to open support case so that I am asking for help :)
Badge +19
@Nezar , can you message me on the side about which CCID this is for?  I show most of your CommCells are in support.
