System State backup error reporting
  • 11 May 2021
  • 369 views
Badge +9
Question: is it possible to add another error code on the same report, for example we send out reports for error id 6:64 but I would also like to include the error code 19:857 on the same report.
Best answer by Mike Struening RETIRED 11 May 2021, 20:23
Hey @gary mcneely !  Thanks for the question.  My initial thought is that it isn’t available because various error codes can have little to do with each other, and the expectation is to just create multiple report/schedules though I imagine you want it in one report, for either error.
Is that correct?  I can see if this will be acceptable as a CMR once you confirm.
