Transferring Ownership of Commvault Report
  • 27 January 2021
  • 272 views
Badge +4
How to transfer the ownership of Commvault report to other user so that they can edit it whenever needed.
Best answer by MFasulo 27 January 2021, 20:11
Badge +12
Hit the ellipsis, next to the report, go to security and add the folks with necessary permissions.
Badge +4
Thanks , I was able to do that from the command center not from the Commvault console
Badge +12
Gotcha, all my posts will be heavily geared toward Command Center, glad it worked for you!
