Trigger external script on failing Jobs
Badge +8
I am looking for a solution which can trigger a script outside from Commvault when ever a backup job is failing. The script needs only give over the failing JOBID.
Plan is to automate a quick analyze of the failure and trigger the right team to fix the issue without manual invention.
thanks in advance for your suggestions.
regards Jürgen
Best answer by Blaine Williams 3 May 2021, 12:27
Userlevel 5
Badge +8
Hi Juergen,
You can use the alerts and notifications on failed jobs to trigger a command line to run scripts if you require.
Alerts : https://documentation.commvault.com/commvault/v11/article?p=5196.htm
Command Line notification https://documentation.commvault.com/commvault/v11/article?p=5401.htm
However if you just want to notify the teams when there is a failure with details just use CV to do it. You can then configure separate team responsibilities between alerts and have it notify them.
Creating an Alert : https://documentation.commvault.com/commvault/v11/article?p=5203.htm
There is also a predefined alert already created you can copy and modify.
https://documentation.commvault.com/commvault/v11/article?p=5199.htm#o131659
Backup job failed
Job Management / Data Protection
This alert notifies the user when a backup job fails to complete, fails to start or is stopped by the system
Badge +8
Hi Blaine,
thanks, that was exactly what I am looking for, sometimes you see the wood not because of the many trees (German proverb) :sweat_smile:
regards Jürgen
Our version is “Not seeing the forest for the trees” :joy:
Userlevel 5
Badge +8
You Welcome Juergen.
Our version is “Not seeing the wood for the trees”
