I am looking for a solution which can trigger a script outside from Commvault when ever a backup job is failing. The script needs only give over the failing JOBID.
Plan is to automate a quick analyze of the failure and trigger the right team to fix the issue without manual invention.
thanks in advance for your suggestions.
regards Jürgen
Best answer by Blaine Williams
