I try to enable livesync ont the prod customer commserve.
In the control panel\Commserve LiveSync, I have selected the checkbox to Enable Livesync.
The name the instance002 on each commserve is ok
I have selected the default CommServeDR, in connectivity I have chosen Use Existing Configuration and leave all by default.
after 5 mn the Console is stuck. “Commserve Livesync datasaving in progress ...”
When I verify naming in the process manager, I notice that the client name of each Instance002 contains _NODE at the end, but on the console the name is ok. Do you know why it appears ?
Thanks !
when I go to process manager of each commserve I have :
PROD
Client name commserve
Client Hostname csprod.mycustomer.com
Instance Name Instance001
CommServe Hostname csprod.mycustomer.com
CommServe Name commserve
Client name csprod-SQL_NODE
Instance Name Instance002
STANDBY
Client Hostname csdr.mycustomer.com
Client name csdr-SQL_NODE
Best answer by Bloopa
