VCSA Backip failed - VDDK version too low
  • 29 July 2021
  • 7 replies
  • 1264 views
Userlevel 1
Badge +2
Hallo CV community,
recently we got this error while using the SAN transport mode with auto scheduled jobs.
Failure Reason:
·  ERROR CODE [72:106]: VDDK Version 6.5 is required to back up virtual machines on hosts running ESX 6.5 using SAN mode. The VDDK will be auto updated on the next attempt.
We are using
VMware vCenter Server
Version:
7.0.2.00200
Build-Nummer
17958471
Any ideas regarding this issues.
BR
Philipp
Best answer by Philipp 30 July 2021, 08:15
Badge +15
Hi @Philipp !
What’s your current Commvault version ?
Then check through this link for the VDDK / VCenter server version VS Commvault
https://documentation.commvault.com/commvault/v11/article?p=3368.htm
If your VCenter is in v7, are the ESXs hosts also in the same version, or stil in older version?
Badge +14
HI Philipp,
Also, check on the VSA Proxy(ies) you do not have the below registry key configured at a lower version:
Seb
Userlevel 1
Badge +2
Hi Seb,
thanks - i checked that - it was not Enabled but i removed that key right now.
Also i disabled the last key in this picture regarding the vStorageTransportMode.
Best regards
Philipp
now:
Userlevel 1
Badge +2
Hi @Laurent
→ All ESXi Hosts are 6.5 latested version
Commvault should auto-select the correct version of VDDK depending on the vCenter version you are connecting to. Does the VSA proxy have the correct feature release version on it? almost sounds like it was an older install which has not been patched.
Also, check the registry of the client itself, just in case some legacy / manually input keys are still around.
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\CommVault Systems\Galaxy\Instance001\VirtualServer
Userlevel 1
Badge +2
All machine were backup successfully - after the themselves the VDDK version.
Seams to be OK right now.
Thanks all for your reply's.
BR
Philipp
Badge +14
Excellent.
