View option in Job History from Admin console
  • 12 July 2021
  • 9 replies
  • 177 views
Badge +2
Hi Team,
In one of my customer’s Admin console I’m not able to see View option in Job History from Admin Console.
Please let me know what things I need to enable to see the option like mentioned in below screenshot.
Best answer by Harsha 28 August 2021, 09:56
Userlevel 2
Badge +3
Hello Harsha,
Are you able to see it for your other customer? Are you using the same account to access the Command Center?
Thank you,
Sandip
Badge +2
@Sandip Domadia Yes Sandip, for other customer accounts I can see that option and using same cred’s for command center login.
Userlevel 2
Badge +3
Do you have another account you can test with? I would recommend opening a support case.
Thank you,
Sandip
@Harsha , please share the incident number so I can track it.
@Harsha , following up on this one.  did the customer open a support case?  If so, do you have the case number?
Badge +2
@Mike Struening Sorry for late reply; currently we are checking with Dev team on this issue.
Hey @Harsha , gentle follow up to see if you have a solution to share.
Badge +2
@Mike Struening  This issue been resolved. We did find that User has been enabled the Custom view over his account; so we after deleting the custom view and after reopening the command center we could see the “View” option after job history.
Thankyou.
Thanks, @Harsha !
