Virtualize Me option missing
  • 23 February 2021
  • 218 views
Badge +10
  • Commvault Certified Expert
  • 46 replies
Hi all!
Based on documentation (11.22) there should be an option for P2V (Virtualize Me) in Command Center:
https://documentation.commvault.com/11.22/essential/98093_performing_virtualize_me_for_windows_or_unix_computers.html
There is no such thing in my case:
What am I missing?
Version: 11.22.9.
Best answer by euMike 23 February 2021, 19:07
Badge +10
Nevermind, found the solution.
There is an additional setting “showVirtualizeMe” and it is disabled by default.
Restarting the services and voila.
That has to be the fastest self answering post I’ve seen in a while :-)
I’ll go ahead and mark your reply as the Best Answer for posterity!
Userlevel 1
Badge +3
Hi @euMike ,
Can you confirm if the recovery target is created? If not, can you please follow the doc link and confirm if you are able to see the option without the need for additional setting.
Karthik
Badge +10
Hi Karthik,
Yes, recovery target was already created along with first System State backup of that particular client.
