Hi, I need to add 500 virtual machines to a subclient. Is there a script to add them all?
  • 7 November 2022
  • 79 views
Badge +4
Userlevel 5
Badge +13
You can try with this: https://documentation.commvault.com/2022e/expert/32416_adding_virtual_machines_to_subclient_vmware_command_line.html
Badge +10
I would ask why?
In my mind, adding vm’s into the subclient itself is not wise.
You should rather configure vm backups via discovery, using something like tags, then tags the vms.
Badge +2
did you come up with a solution? I have a similar scenario as well!
Badge +14
Hi @EJIE , @Just Learning ,
Can you check the Best Practices:
https://documentation.commvault.com/2022e/expert/32572_best_practices_for_virtual_server_agent_with_vmware.html
Let me know if you have any questions please.
Sebastien Merluzzi
