Hi, I need to add 500 virtual machines to a subclient. Is there a script to add them all?
I would ask why?
In my mind, adding vm’s into the subclient itself is not wise.
You should rather configure vm backups via discovery, using something like tags, then tags the vms.
did you come up with a solution? I have a similar scenario as well!
Hi
Can you check the Best Practices:
Let me know if you have any questions please.
Sebastien Merluzzi
