Can a VMWARE VM be restored retaining its original UUID?
Best answer by Gopinath
View originalCan a VMWARE VM be restored retaining its original UUID?
Yes, and this will happen by default as long as the original machine is gone. If you restore a copy of the VM and the original still exists, a new UUID will have to be generated as duplicates are not allowed. Most customers ‘keep’ the original VM when restoring a new one, at least temporarily until they are confident that its safe to delete the old one, so just keep that in mind. One way around this is to clone the original VM, then delete the original to free up the incoming UUID for the restored machine.
Thanks. Will the UUID be retained in case of unconditional overwrite as well or the original VM needs to be deleted first?
On doing a full VM in-place restore with unconditional overwrite will retain original uuid as it uses CBT based restore and same on non-cbt based full vm restore with unconditional overwrite. When source VM is present on the same host/cluster, restored VM will get new uuid on doing to out of place restore with different vm name, to avoid id collisions.
Regards
Gopinath
Thank you. But the two statements appear to be conflicting. Overwrite implies Source VM is present.
So are you saying overwrite will retain the uuid as per your first statement or a new uuid will be generated as per your second statement?
Thank Sandy! updated it. Overwrite will retain the uuid. out of place restore when source present will give new uuid to restored vm.
Perfect, thanks
