Vmware restore - Remove In Place and undconditional overwrite
  • December 3, 2021
  • 247 views
ApK
Novice
Hi all.
I would like to restrict my restore users, so that they cannot restore on top of a running Vmware server. I always want them to restore to a new server name, so somebody cannot destroy a running working server.
Would it be possible to remove the In Place restore option when restoring a vmware server, and force the users to restore to a new server name.
And when restoring to a new server name, would it be possible to remove the option to do a unconditional overwrite so that a user cannot overwrite a running server?
Thanks.
-Anders
Best answer by Anand Lunawat
Hi APK,
Are you trying with admin user or end user ?
Also removing the “In Place Full Machine Recovery” should work fine for Full VM restore.
Forum|alt.badge.img+2
  • December 3, 2021
You may be able to do a custom role and remove the right for “In Place Recover” “In Place Full Machine Recovery” and Overwrite on Restore”
MichaelCapon
  • December 3, 2021
Hi @ApK ,
Do you have a role assigned to the users that you want to restrict? - I would suggest removing the following permissions:
  • In Place Recover
  • In Place Full Machine Recovery
  • Overwrite on restore
Refer to the Documentation links below:
Security Configuration: https://documentation.commvault.com/11.22/essential/87204_security_configuration_for_virtualization.html
Managing Roles: https://documentation.commvault.com/11.22/essential/86846_managing_roles.html
Michael
ApK
Novice
  • December 3, 2021
Hi @Terry I and @MichaelCapon .
That was my own thoughts, but if I remove the “Overwrite on restore” my guess would be, that I remove it from all kinds of restore methods like removing the possibility to overwrite a SQL, file, Oracle etc.and that is not an option.
  • December 6, 2021
Hi APK,
ApK
Novice
  • December 6, 2021
@Anand Lunawat I have created a Backup & Restore role for end users so they are only able to do a backup and a restore, but I would like them not to be able to overwrite a running vm
@ApK , can you confirm that @Anand Lunawat ‘s suggestion was not adequate?
