httpclient activity not passing header value
  • September 21, 2023
  • 7 replies
  • 191 views
christopherlecky
Explorer
Forum|alt.badge.img+21
Here is the form activity.
Now here is the logs…
SetActivityInputs: starting activity with inputs [<inputs><request><method>POST</method><postType>Form</postType><postContent /><postContentType>application/json; charset=UTF-8</postContentType><headers><name>Accept</name><value>application/json</value></headers><headers><name>Authorization</name><value /></headers></request></inputs>]
As you can see the value for authorization is empty.
The variable is set, but no matter what I do it refuses to honor it.
Best answer by Navneet Singh
@christopherlecky
If you are using a POST operation then Content-Type Header should get used.
If doesn’t work then please follow the below DOCs and try.
https://documentation.commvault.com/2023e/essential/131558_adding_input_to_workflow.html
https://documentation.commvault.com/2023e/expert/49530_creating_sample_workflow.html
https://api.commvault.com/
Forum|alt.badge.img+13
@christopherlecky
christopherlecky
Explorer
I tried content-type earlier, I switched to form out of desperation.If you look at the logs you can even seen that content-type is being sent.
Graham Swift
  • September 22, 2023
Hi @christopherlecky ,
Just tried this in my lab. I wonder if your variable vCenterAuthString is not getting populated. If I run it I am getting the value populated.
SetActivityInputs: starting activity with inputs [<inputs><request><url>https://vcenter.lab.local/api/session</url><method>POST</method><postType>Raw</postType><postContent /><postContentType>application/json; charset=UTF-8</postContentType><headers><name>Authorization</name><value>Basic EncryptedUsernamAndPassword</value></headers><headers><name>Accept</name><value>application/json</value></headers></request></inputs>]
christopherlecky
Explorer
It is, when I run debug I can see the value.
christopherlecky
Explorer
it was a typo
Graham Swift
  • September 23, 2023
Glad you cracked it!
christopherlecky
Explorer
@Graham Swift thanks.
