Is it Possible to get hostName from ClientID
  • Oct 13, 2023 2:15 PM UTC
  • 139 views
I’m integrating CommVault API in order to have all client ( VM, client which make backup and Kubernates Application) in a single dataframe.
/client route returns hostName,clientName,displayName
/VM  returns several information of which returns clientName,displayName but not HostName
/v4/Kubernetes/Applications return several information of which name but not displayName and HostName
While I know that a VM may not have a phisical hostName and kubernates Applications may not have an hostName since it’s dockerized containers, it is possible to have the hostName for Kubernates and VMs?
/client has all 3 name columns(hostName,clientName,displayName)
/VM has 2 name columns(clientName,displayName)
/Applications has only one name column (name)
Or, I can do the assumption that
VM Client Name can be added to hostname
Kubernates application names can be considered as HostName?
like hostName = clientName = name ?
Thanks for all the clarification
Best answer by John_DE
Hi, I’ve solved by using the clientName field that is present in VM and /client.
Thank you for your solution
Hello @John_DE
Thank you for reaching out to Commvault Community! Just to confirm, do you need to just pull VM hostnames using API? If so, you can try using the API below:
GET http://WebConsoleHostName/webconsole/api/VM?guid=502d4368-5d71-1341-dd53-e1ffbf4f9b0d
The GUID is just a sample, however, this will pull the hostname for the the VM as per the screenshot below (VMHost):
You can find more examples of API’s from our API site below:
https://api.commvault.com/
Please let me know if this helps!
Chuck Graves
  • Oct 19, 2023 1:57 PM UTC
