I am a very beginner with workflows and I am facing my first problem:
I want to run a backup for all subclients for a specific client beside a subclient “test” via workflow.
So in this example at the beginning of that workflow I manually choose a client.
This client has serveral subclients (e.g. “data1”, “data2” and “test”).
The discover of DataAgent, BackupSet and all Subclients works fine, but with which activity in the Workflow Designer can I exclude the pattern “test” in the list of subclients?
I’ve tried the “RemoveFromList” but without any success (or maybe I used it the wrong way).
![](https://uploads-eu-west-1.insided.com/commvault-eu/attachment/66f229a1-7db3-46e7-8817-73a782128ca5.png)
Do you have a clue?
BR
Best answer by Scott Moseman
