Browse all versions of a guest file for a specific VM with API DoBrowse
  • January 26, 2023
  • 177 views
I’m used to use your API, but in this case, I can't get what I want 😪
Use case : Before perform a single file restore operation, I need to see all versions of a guest file for a VM backuped without agent (agentless) .
I use the DoBrowse API, but I have no usable results.
{{ServerUrl}}/DoBrowse (POST) with body:
"opType": 0,
"queries": [
"type": 1,
"queryId": "countQuery",
"aggrParam": {
"field": 0,
"aggrType": 4
"type": 4,
"queryId": "dataQuery",
"dataParam": {
"sortParam": {
"ascending": true,
"sortBy": [
38,
0
"paging": {
"firstNode": 0,
"pageSize": 15,
"skipNode": 0
"mode": {
"mode": 1
"paths": [
"path": "\\50003816-5EF5-1648-8ED1-0FD0B08F024C\\var\\log\\cron"
"options": {
"showDeletedFiles": true,
"restoreIndex": true
"entity": {
"subclientId": 26475,
"applicationId": 106,
"clientName": "myhostname",
"instanceId": 119,
"clientId": 3903
"timeRange": {
"fromTime": 1643207640,
"toTime": 1674743640
The poor response is (Status code : 200) :
"browseResponses": [
"respType": 0,
"workerId": "69973",
"doClientSideSortingAndPaging": false,
"session": {
"sessionId": "1674744084-69973"
"browseResult": {
"aggrResultSet": [
"result": 0,
"groupbyValue": "",
"count": 0
Wath is the correct request to obtain all versions for a specific guest file (during the retention period of course) ?
Current version : 11.24.86
Best answer by Damian Andre
Hey @mjc
Have you been able to do this outside of the API? I only ask because by default Commvault would not have an index of the VM backups to know all the versions or even have a file list. The VM backups need to be indexed to get this sort of data otherwise it needs to establish a live browse.
https://documentation.commvault.com/2022e/essential/144093_file_indexing_version_2.html
Before tackling the API stuff, just wanted to make sure the infrastructure is set up to enable this to work.
  • January 26, 2023
Hey @mjc
  • January 27, 2023
Hello, thanks to @Damian Andre . You’re right, this option is not yet enabled on our configuration.
I see that your refered to version 2 that still available with 2022E version. We’re update to this version asap and I come back if necessary.
