Copies for JOB ID (VMbackup) API Commvault
  • January 9, 2024
  • 46 views
Michal128
Explorer
Forum|alt.badge.img+9
Hello All,
I working with API connection. I would like to receive where is located VM backup JOB by API. I can get job ID for VM, but I can’t received which copy store that data from storage policy. Good question how I can get it?
Hello @Michal128
The following will provide a summary of the jobs and their retention:
https://api.commvault.com/#48b0b104-93ea-42bf-a67c-eca784c50e63
Given retention is copy specific it may give multiple entries per copy and all their details.
Hope this helps!
Kind regards
Albert Williams
Hello @Michal128
Hope this helps!
Kind regards
Albert Williams
