DB2 Worklow
  • April 24, 2023
  • 43 views
New to workflows and Commvault in general, having deployed in December of 22. Looking for a workflow that would enable our DB2 DBAs to do an out of place restore to devops server using the repath options on a weekly basis.
christopherlecky
Challenger
Forum|alt.badge.img+16
You don’t need a workflow to do this.
You can do it via rest.
Just do the restore in the command center. Copy the api equivalent and you can edit the parameters.
