Well here is a good one…
Is there a way to hide the inputs of a popup activity using java or javascript?
That’s definitely interesting. Can you share some of the use case a bit?
Tagging in
On the customize input screen there is a hidden option.
so for example, screen two would be altered by the options selected on screen 1.
Absolutely awesome answer. I typically use the Java gui for editing workflows so it doesn’t show up there as an option. I was under the impression that I would have to modify the object itself. This is a much better solution since it requires no coding and probably just uses JS to edit the page.
thanks,
The feature isn’t working for me. Should this work within the same page?
Unmarking as Best Answer.
The ticket is opened: 220218-540
The issue is that the rules are failing to work.
The ticket has screenshots and the CS and Workflow DB is currently being staged. I have another topic here for using workflow objects since the issue of the rules not working does not seem to apply to the workflow itself but rather to user interaction activities.
That said setting the rules on a workflow input would require a way to do a query prior to the form loading.
Thanks for the case number,
Awesome, Brian sorted me out as expected.
Turns out it was a simple misunderstanding of the term “hidden”
Brian is a gem!
