Modify Alert recipients in Bulk using API
  • Dec 14, 2023 12:05 PM UTC
  • 89 views
Robert Horowski
I am trying to modify alerts assigned by default to admin user and master group to some other users/groups. I have found another thread where @Venu Kondabhathini  suggested using API.
I am trying to use JSON file from
https://documentation.commvault.com/2022e/essential/rest_api_post_alert_modify.html
But when I am trying to load this it gives me an error:
$body = Get-Content -Raw -Path $pathToJSON | ConvertFrom-Json
ConvertFrom-Json: Conversion from JSON failed with error: Unexpected character encountered while parsing value: }. Path 'alertDetail.alertDetail.appTypeFilterList.appTypeFilter[0]._type_', line 15, position 16.
I am using Powershell.
Is anyone using this? Is this file broken?
Best answer by Venu Kondabhathini
Hi Robert,
Thank you for asking the question in the community.
The error shows that _type_ parameter in AppTypeFilter list is incorrect in Line 15.
The correct value for _type_ is 79 when used with applicationID
Below are the applicationID
_type_
Valid value is 79 when the applicationId parameter is used, for example:
<appTypeFilter _type_ ="79" applicationId ="53"/>
appTypeFilter
appTypeFilterList
applicationId
This parameter is available for alert types that can be associated with agents. Filters the entities in the <associations> element.
Valid values are:
  • 53, for Exchange Database
  • 33, for File System
  • 104, for MySQL
  • 13, for NAS
  • 59, for Notes Database
  • 22, for Oracle
  • 80, for Oracle RAC
  • 125, for PostgreSQL
  • 79, for SAP for MAX DB
  • 61, for SAP for Oracle
  • 81, for SQL Server
  • 5, for Sybase Database
  • 29, UNIX File System
  • 106, Virtual Server
appTypeFilter
appTypeFilterList
Could you please share the Json file with fields filled for further review.
Regards
Venu Kondabhathini
Hi Robert,
_type_
appTypeFilter
appTypeFilterList
applicationId
Valid values are:
  • 104, for MySQL
  • 13, for NAS
  • 22, for Oracle
appTypeFilter
appTypeFilterList
Regards
Venu Kondabhathini
