powershell api - getting data not working - etc get-cvsqlinstance data
  • 17 February 2023
  • 221 views
Hello All,
i’m facing a issue where commands like get-cvsqlinstance -name “xxxx\xxx” is not working. Going through documentation from CV describes that i’m doing the correct thing.
although still getting internal error 500
powershell error :
ValidateResponse :
Status: ProtocolError
Message: The remote server returned an error: (500) Internal Server Error.
ErrorMessage:
RecommendedAction:
At C:\Users\nnit-ceen.BCK\Desktop\CVPowershellSDK-master\CVPowershellSDK-master\Modules\Commvault.RESTSession\Commvault.RESTSession.psm1:410 char:17
+                 ValidateResponse $response $output $ValidateProperty
    + CategoryInfo          : NotSpecified: (:) Write-Error], WriteErrorException
    + FullyQualifiedErrorId : Microsoft.PowerShell.Commands.WriteErrorException,ValidateResponse
any clue the above?
Badge +14
Hi @Claes ,
I had the same issue, did you reinstall the Commvault Powershell module?
https://documentation.commvault.com/2022e/essential/124529_installing_commvault_powershell_sdk_from_github_most_recent_version_of_module.html
Sebastien
Badge +1
Hi @Claes ,
Sebastien
i downloaded the powershell package from: https://github.com/Commvault/CVPowershellSDK
ran the offline install method, and made the following ps script
$commServer = "server"
$commUsername = "user"
$commPassword = ConvertTo-SecureString "password" -AsPlainText -Force
Connect-CVServer -Server $commServer -User $commUsername -Password $commPassword
Get-CVSQLInstance -ClientName "client-server\i01"
Disconnect-CVServer
and this is giving the above error before…. regardless of what sql server instance i give.
Badge +14
And typing command Get-CVSQLInstance -ClientName "client-server” doesn’t work?
Badge +1
nope :(
PS C:\Users\ceen\Desktop\CVPowershellSDK-master\CVPowershellSDK-master> Get-CVSQLInstance -clientname "client-server"
ValidateResponse :
ErrorMessage:
RecommendedAction:
    + CategoryInfo          : NotSpecified: (:) [Write-Error], WriteErrorException
INFO: Get-CVSQLInstance: no SQL instances found for client [client-server]
and i know this is not true about sql instances not found… i have around 1000 sql serves, some of them contain multiple sql instances…. so far im getting error on all of the servers i have tried..
Badge +14
Strange, you also tried from a remote server, like your laptop or Media Agent?
