Aix & DataDomain DDBoost over Fiber (SAN)
  • June 2, 2026
  • 7 views
How may I know if my Aix environment is supported with DataDomain DDBoost over fiber?
Commvault Version: 11.40 release 22
Commvault Media Agent SO: AIX 7.1/7.2
We have a large Oracle DB with 50Tb that we would like to protect.
  • June 3, 2026
Hi ​@FTenorio,
AIX MediaAgents can be installed and used for basic data movement, but cannot host deduplication (DD) stores—which means they cannot act as the MediaAgent for Data Domain DDBoost libraries (over Fibre Channel or IP).
The  AIX MediaAgents to directly host or manage Data Domain DDBoost libraries is not supported.
For DDBoost integration (including over Fibre Channel), you must use a supported MediaAgent OS such as Linux or Windows (x64), as per the documentation below.
https://documentation.commvault.com/11.40/software/support_for_data_domain_boost_client.html
https://documentation.commvault.com/11.40/software/support_for_data_domain_boost_access.html
Karthik
RubeckDK
Explorer
  • June 3, 2026
Sorry for buggin’ in…. I might be wrong, but the question seems be related to client- direct… Installing the Storage Accelerator and Storage Accelerator Add-ons on the client seems as all there’s needed (unlike in v.11.32 where the Media Agent component is required to be installed). Client writes /ready directly to the DD and backend Media Agents host the meta data (index etc).  So no CVLT dedup will be used in such scenario..
/RubeckDK
