Compliance Lock Self Service
  • Feb 26, 2024 11:27 AM UTC
  • 2010 views
Forum|alt.badge.img+16
Good afternoon
I just received this new Article in my mailbox.
https://support.commvault.com/Article/Details/82504
According to this article I can now request a Compliance Lock on the support portal.
Previously, a document needed to be filled in by the customer and signed/approved prior to the codes being supplied.
From what I see, this new process has removed the requirement for customer approval and has given the full authority to one individual with Maintenance Advantage access.
Is there any comment on what I’m understanding? I don’t have a test environment to understand how this new process works and it’s less/more secure than the previous procedure.
Mauro
Best answer by Brian Bruno
Hi @Mauro,
Thank you for your question!  Although we have removed the requirement for Customer Support to be directly involved in these requests, and have also removed the requirement for the signed document to be provided on company letterhead, we have not opened this up for a single individual to remove Compliance Lock.
This new self-service portal form is only supposed as of 11.32 (Commvault Platform Release 2023E) and beyond.  Beginning with this release, any attempt to disable Compliance Lock triggers a Multi-Person Authorization workflow.  The operation will essentially be queued until another user with Administrative permissions accepts the request.
As soon as the command is executed, the user will be notified in the command prompt that the process will not be completed until multi-person authorization is satisfied.  I have run through a test of this in my lab to showcase the behavior.
Here is the notification the executing user will see once the script has been executed:
The users that are configured to receive multi-person authorization requests (by default, all users in the [master] group) will receive an email such as this:
Additionally, those same users can see the same request in the Command Center’s Monitoring > Approvals Dashboard:
Compliance Lock will only be disabled once another Master user approves the request.
I hope this answers your question!
-Brian Bruno
  • Feb 26, 2024 5:07 PM UTC
Hi @Mauro,
-Brian Bruno
Gergely (Sydney)
@Brian Bruno, do you know if it’s controllable which user(s) can approve.
Yes, This is configurable under GetAndProcessAuthorization Workflow Configuration tab:
If the request is sent by an admin account and there is no other admin (master) account, the request is approved automatically:
Gergely (Sydney)
  • Mar 6, 2024 11:20 AM UTC
Thank you for all the feedback on this.
I’m going to set this up in my lab and simulate a few scenarios based on what we’ve encountered in the field.
I will update this thread with what I’ve managed to test.
