Disk Library Mount path space usage monitoring
  • January 30, 2023
  • 303 views
Mohit Chordia
Explorer
HI Team,
Is there any API or report using which we can monitor individual library mount paths ?
CV alerts are for complete library but i need to configure an alert specific to mount paths( coming from different media agents or servers ) part of same disk library.
We receive below alerts when one or few of the mount paths of library met reserved space .
Failure Reason: Insufficient disk space. Available mount paths are not enabled for write or have met reserved space limit. Enable/add more mount paths or add more disk space to existing mount paths. Please check mount paths on the library
Need to configure alerts on mount path level so that we can disable the mount paths in advance .
Regards, Mohit
Best answer by Zubair Ahmed Sharief
Hello Mohit,
Please check the below if that suffices your requirement.
Prefer mount paths with more free space.
Library Properties (Mount Paths) (commvault.com)
Hello Mohit,
Mohit Chordia
Explorer
  • February 3, 2023
@Zubair Ahmed Sharief
Hello , I need to configure an alert at mount path level -
Example -  if the utilization on mount path space reaches 80% then i should be notify.
