Every time I send an auxiliary copy to tape, it tells me that the Chucks are not available for the operating system. The end user put the MA installation path inside the drive where the backups are located, can this be the cause
Every time I send an auxiliary copy to tape, it tells me that the Chunks are not available for the operating system.
When you see an error, can you see if the chunk file in question is actually there or not?
If not, then you’ll need to see why it was deleted.
If it is there, my initial suspicion would be that you have some Anti Virus program monitoring that folder and locking the files.
This exclusion list is worth a look:
I note that the CV_MAGNETICS are on a route of a VM of Azure, when I present this path on the librari this appear that is online.
But after the sent the beging Data Verification or a Auxiliar Copy this apper who no accesible.
Can you open a support case for this issue and share the case number?
Based on what
