HPE StoreOnce Catalyst: support for high-bandwidth? how to enable?
  • August 1, 2024
  • 10 replies
  • 675 views
We are implementing a new StoreOnce system as primary copy and test performance (and other topics) between FC-catalyst stores and FC-Virtual Tape Libraries
A Catalyst Store on StoreOnce can be configured either as high-bandwidth or low-bandwidth
  • high-bandwidth: Backup server (media agent in case of CommVault) will send backupstreams unmodified to StoreOnce and then StoreOnce will do dedupe etc. before finally storing the data on its disks.
  • low-bandwidth: already the backup server (media agent) will do de-dupe and only sends new things to the StoreOnce.
VTL is similar to high bandwidth (all goes from MA over FC-SAN to StoreOnce and only there the data reduction takes place).
As we have plenty of ressources on FC-SAN and the StoreOnce is made for doing all the datareduction we’d like to get StoreOnce connected/configured in high-bandwidth for Catalyst, especially as important servers are doing LAN-free backups (have their own media agent locally installed to directly backup over FC) - having them to do the extra DeDupe-work (CPU, RAM,...) is not what we want, the StoreOnce shall do it.
When we force the Catalyst to high-bandwidth we get this error in CommVault
    Error occurred in Disk Media, Path     [CS_Test1\STYMSI_07.18.2024_13.35\CV_MAGNETIC\V_3663970] [-3203     OSCLT_ERR_INVALID_BANDWIDTH_MODE]. For more help, please call your     vendor's support hotline.
when we enable both ways (primary low, secondary high OR vice versa) then CommVault always selects low bandwith (can be seen in backup speed vs. interface usage. there is much less data physically transfered than backup size. thus the media agent is doing dedupe (which we do not want).
any experience / help available? unfortunately neither documentation of CommVault nor HPE is helping us...
Hello @MARamius
Thanks for the details and questions.
Can you confirm if this is a library that has already been setup  in low-bandwidth mode and CV is performing the deduplication of the data and then you are attempting to change it to high?
Or is this a fresh configuration? If so the following goes over the config steps:
https://documentation.commvault.com/2023e/expert/hpe_storeonce_catalyst_library_configuring_catalyst_store_as_commvault_hpe_catalyst_library.html
Kind regards
Albert Williams
  • August 2, 2024
Hello Albert,
we have the problem in both variants:
  • fresh new catalyst store, configured for high-bandwidth only, then in CV a created a new library, to the COFC parameters to use this store.
  • existing catalyst store, already connected to CV via COFC, already containing backups in low-bandwith (i.e. CV did the dedupe and not StoreOnce), then in Catalyst (HPE) change settings to use high-bandwidth only.
Yes, I followed the instructions. also about COFC.
I miss a setting in CV to select the bandwidth mode. Or, that CV would recongnize and accept the bandwidth prefereration set in the Catalyst Store (HPE).
Hello @MARamius
The change from low bandwidth to high i think will always cause you issues. Unless you tell Commvault to stop deduping the data we will always try to do that. When you disable dedup with data already associated it is generally a lot cleaner and safer to just make a new pool and associate the agents there.
In the case of a new config, the doco goes over it all, if you are finding the jobs failing then a support ticket is going to be the next step as it might be a bug.
Kind regards
Albert Williams
  • August 5, 2024
Hi Albert
in the docu I just can’t find any hint, how to tell CV to not DD but let the StoreOnce do it (i.e. to honour the high-bandwidth wish). If you can show me?
We also raised a ticked, however it’s ping-pong between HPE and CV, both claims it’s the other ones fault.
also, just to be sure, we created another “eco-system” from scratch (new Catalyst Store, set to high only, new CV Storagepolicy with new primary copy, new backup set, verified that everywhere in the chain (iDA, MA, SP, ...) everything about DeDupe/… by CV is disabled. Still same result
Error occurred in Disk Media, Path [CS_High_Test\YC1TF9_08.05.2024_08.12\CV_MAGNETIC\V_3664525] [-3203 OSCLT_ERR_INVALID_BANDWIDTH_MODE]. For more help, please call your vendor's support hotline.
Isn’t there any other customer here with Catalyst and CV in high-bandwidth?
Best Regards
Forum|alt.badge.img+2
  • August 20, 2024
Just to clarify here, in low bandwidth Commvalt does not do the dedupe. Its HPE binaries which are integrated into our software, so its still HPE dedupe. Please configure low bandwidth at Storeonce console.
  • August 20, 2024
Hi jitendran,
thx for clarification.
But what we need to achieve: The dedupe (HPE binaries) needs to happen at the HPE box (StoreOnce) and not already at the generic commvault media agent.
i.e. from iDA to MA and from MA to final destination (StoreOnce catalyst library, running on StoreOnce Box) we need the original data, uncompressed, not deduped. Only when it finally hits the destination there shall the HPE binaries do their magic.
Reason: StoreOnce Box is sized to properly do all that extra DD/compression tasks, but the mediaagents are NOT sized that way. and we have high bandwidth fibre channel between MA and StoreOnce Catalyst. So we do NOT need to save bandwidth between MA and S1/Cat. But when we let the MAs do the DD-job we have less throughput (CPU goes 100% on MA, as they are not meant to do DD).
When I do not use Catalyst but VTL then I get what I want: all data comes in raw over the FC, and then the StoreOnce box has to do all the tasks.
But Catalyst has some benefits over VTL, thus we want to achieve the same with Cat.
And that’s what HighBandwidth mode means (according to HPE).
But, I found no way yet to tell CV to use HighBandwidth and not LowBandwidth.
So, again. How to use/configure CV with HPE StoreOnce Catalyst (FC, but should be the same also for Ethernet) to use HIGH bandwith mode, i.e. DD shall only happen at the HPE box, not on the MAs.
  • August 20, 2024
As you can see from the error message which is coming from HPE that high bandwidth cannot be used:
  • August 20, 2024
thx for quick reply:
So, you are saying, from CV point of view: HPE is simply not supporting HighBandwidth with CV?
Because: HPE says: we fully support Catalyst with CV. as long as it is a valid mode it’s the task of the backup ISV to properly select a suiting mode.
I can make selections at HPE (preferred mode, secondary mode). for both modes I can select low or high bandwidth. together with HPE and CV the following choices are working:
  1. pri: low, sec:HIGH
  2. pri: HIGH, sec: low
  3. pri: low, sec. low
what is not working:
  1. pri: HIGH, sec: HIGH.
However, in the selections 1., 2., and 3. the negotiated mode is ALWAYS low.
But, we need HIGH
We know from consultants that HPE StoreOnce Catalyst works in HIGH with Veeam, with DataProtector
Thus we still hope to get CV also to use HIGH. But we found no knob, switch, parameter, setting, … to tell inside CV to use HIGH. only the “external” forcing of variant 4. But, that results in the OSCLT_ERR_INVALID_BANDWIDTH_MODE reply :-(
For us it’s unfortunately ping-pong blaming between HPE and CV. both sides says HIGH shall be working and it’s the fault of the other side :-(
  • August 22, 2024
We consulted the HPE engineers who were involved with the initial integration and this was their response (see below in quotes).
High bandwidth is not supported. So we recommend you to use low bandwidth and check performance.
“High BW mode is a legacy mode and does not support all Catalyst features that Commvault uses.
In our initial Commvault/Catalyst integration discussions we requested that Commvault only support Low BW mode, so it could make use of all Catalyst features without compromise.
Usage of fixed block chunking for VM and HANA backups has to be done with Low BW mode, as it is done by the Catalyst client.
Catalyst clone is also *much* less efficient if not done in Low BW mode.
Both these features enable backups to be completed much faster and more efficiently than could be achieved with High BW mode.
Furthermore since with Low BW mode (aka source-side dedupe mode) there is very little data to be transferred, backup across WAN and usage of IPSEC to secure data across the wire between Catalyst Client and Server are very viable.
High BW mode was only ever of value to customers running media servers, 10-15 years ago,  on ancient proprietary unix platforms, whose CPUs had awful performance (so catalyst client-side variable chunking, hashing and compression was very slow). These platforms are now all obsolete. Today systems have many powerful CPU cores and the bottleneck is pretty much always the network BW achievable between Catalyst Client and Server, not the media server CPU.”
Nikos.Kyrm
Forum|alt.badge.img+16
  • Community All Star
  • August 5, 2025
I think this is the point here!
