IntelliSnap Support for NetApp ASAr2
  • October 23, 2025
  • 27 replies
  • 372 views
JAnger
Apprentice
NetApp is currently selling the successor to the ASA (SAN Only), the ASAr2, at an attractive price. Basically, it is a system from the ONTAP family, like the FAS or AFF systems. Unfortunately, the API has changed considerably, and Commvault does not yet support the ASAr2 API. I’ve heard that integration is being worked on. Is there a timeline for this?
We have a few projects where Commvault (new customer) and NetApp would be a good combination.
Sureshkumar S
Hi ​@JAnger ,
Good day!
I have checked and at this point there is no ETA
Our Engineering team is working out on the same.
Sureshkumar S
  • January 12, 2026
Hey Guys, ​@Sureshkumar S ​@JAnger
Unfortunately or not, we’re on the same boat. Just curious - have you heard back anything on this? :)
Forum|alt.badge.img+20
  • Challenger
  • January 13, 2026
Hi ! We are strongly willing to use this feature, and just discovered this.
What is the status ?
Where is the blocking point ? On the Commvault side or on the NetApp side?
Laurent.
  • Challenger
  • January 13, 2026
Laurent.
Reached out NetApp experts and they replied that this is on the Commvault side.
So we need to get a ETA or push to get this in the pipe for next updates.
  • January 13, 2026
@Laurent According to NetApp KB, it looks like they’re asking to check with Commvault Support. I assume Commvault is where the traffic is right now. I’ve submitted a support case late last year and it doesn’t look like they have an ETA yet.
Commvault Intellisnap backups fail on ASA r2 platform - NetApp Knowledge Base
Lam.
  • Challenger
  • January 13, 2026
Thanks I got the same feedback. Can you share the case ID you filed to Commvault support so we can insist ? I will right away log one on my side.
Anyone from Commvault staff here in the right section, please don’t hesitate to contact us for this.
EDIT : CMR 539758 posted.
  • January 13, 2026
Apologies, we actually raised this case back in July as we were in the early stages of setting up the ASA. Case 250619-726.
Lam.
JAnger
Apprentice
  • January 19, 2026
NetApp has announced that Commvault support is expected in Q2 2026.
  • January 19, 2026
Hi ​@JAnger, any chance you can share the link or website to where the announcement was made.
 Lam.
JAnger
Apprentice
  • January 19, 2026
@Lam K No, unfortunately not. I got the information from a colleague who participated in a "NetApp ASA R2 Workshop". I only have a screenshot of the slide.
  • Challenger
  • February 17, 2026
still pushing for this one.
Got 0 news / update for my CMR 539758 😏
Onno van den Berg
Forum|alt.badge.img+24
@Sougato Roy can you be of help here? There are several customers waiting for Commvault to resolve the missing support issue.
Sougato Roy
  • February 24, 2026
Thank you for flagging this, Onno. I’m looking into the issue internally and will update you as soon as I have more information.
Roy
Sougato Roy
  • February 24, 2026
Roy
Note: Awaiting details from Product & Engineering. Will come back to this once I have an update.
  • February 24, 2026
For the ASA R2 support, we are currently targeting May in our innovation 11.42 release which will roll into our mainstream 11.44 release in June.
Sougato Roy
  • February 24, 2026
@Onno van den Berg and everyone in this thread:
Please see update from our team here.
Let me know if there’s any other information needed.
Thank you,
Roy
JAnger
Apprentice
  • February 25, 2026
Are there plans to include support in 11.40 as well? Many customers tend to be conservative when it comes to Commvault release updates.
Another question would be, will SnapMirror active sync be supported?
  • February 25, 2026
Due to the significant changes required to add this support we currently do not plan to backport it. This effort is to add our existing supported features to include ASA R2, since we currently do not support SnapMirror active sync, that will not be added as part of this effort. If this is an ask, please reach out your Commvault account team to open a CMR for this specific feature.
Sougato Roy
  • February 25, 2026
@JAnger  Hi,
Please find an update on your query from our team.
  • Challenger
  • February 27, 2026
OK, thanks for the updates.
I had a high when reading that it’s in the pipe, got a down when I saw it would only be for ‘old’ LTS versions.
Got another (huge) down when I read that the SM-AS / SnapMirror Active Sync would not be supported.
We have bought pairs of Netapp ASAr2 storage arrays, each to be setup/paired using SMAS, and initially planned to backup VMWare VM groups using Intellisnap for Netapp with those arrays, to avoid long-time running snapshots with the traditionnal ‘streaming backup’.
I do not plan to use Commvault to orchestrate the data/array replication between two ASAr2 arrays using SMAS.
Now, this beeing written, can I have a clearance on what is expected to be ‘supported features’ in the 11.42/11.44 ? And what would not ? ​@BClarke or ​@Sougato Roy ?
(topic marked as solved, but it’s not from my point of view, or should we fork to a new conversation?)
Sougato Roy
  • February 27, 2026
@Laurent ,
I’m reopening this thread so we can keep the discussion going here. I’ll connect with the team and ask them to provide guidance in this thread.
Thank you,
Roy
  • Challenger
  • May 21, 2026
Hello, what are the news so far please?
Sougato Roy
  • May 21, 2026
@Laurent Hi,
Apologies for the delay on this. I’ve reached out to the team to get a definitive answer for you.
We’ll provide an update here at the earliest.
  • May 25, 2026
For the ASA R2 support, in 11.42/44 we will have primary snap support. Due to changes in how the replication works between Full Ontap and ASA R2, there are significant changes to be made in order to support it. So it will be in the next phase of our support. No current ETA as of yet for replication support.
Sougato Roy
  • May 25, 2026
@Laurent Please find the update to your question here.
