Answer
Recovery Point from AUX Copy
  • March 7, 2022
  • 14 replies
  • 284 views
Hi All,
The Adminconsole showing the recovery Point of the client in Dashboard and as per my understanding Recovery Point refers data available from Primary Copy.
Sameway,  how can I get the receovery Point from secondary copy?
Any report and any way to get the information?
Thanks in Advance
Mani
Best answer by Mike Struening
I got some new info!
Try the Recovery Readiness on Copy custom report in the CV store:
https://cloud.commvault.com/webconsole/softwarestore/#!/135/663/13114
Let me know if that fits your need!
@Manikandn , thanks for the post!
Can you clarify what you are looking at (screenshots would be great)?
Recovery Point could refer to SQL, or Snapshots, or more.
  • March 8, 2022
Hi Mike,
The scenerio is, I have a client “A” located in site Ukraine.  Primary copy configured in On-Prem Storage and Seconday copy move to Azure.
AUX copy is running state and aroud 50 TB data needs to copied.
Now, I want to know, if there is a disaster in the site, What is my RPO for the client A. Means, exactly which point (Date) I can restore the data from my AUX copy.
Mani
Ok, that makes sense.  So essentially you want to know how up to date the RPO is based on how complete the aux copy is?
Let me look into this.  I’m not sure if we show any differentiation on RPO per source.
Can you share a screenshot of what you are seeing so I can track that down with the right people?
  • March 28, 2022
@Mike Struening ,
I couldn’t see anything to get the details. I am check the possiblities
Ok, keep me posted.
@Manikandn , following up on this one.  Any new findings on your side?
Let me know if we can close this one off.
  • June 6, 2022
Hi Mike,
I am looking a answer something different.
The Report shows the RPO from my Primary copy.
Let’s assume, I have a site “A” backing up 100+ clients and has BET 800 TB. There is an issue in the AUX copy due to network and around 200TB data in to be copied state.
I want to highlight that, in case of something goes wrong in the DC, we will be in trouble and want to say the RPO for each client from Primry copy and Secondary copy.
In that situation, which report do I need to refer?
Mani
Thanks for clarifying!  I unmarked the best answer.
I’m not aware of any report that goes that deep into RPO.
I would suggest 2 routes:
  1. Reach out to your account rep regarding a custom report
  2. Contact Customer Support and have a CMR created to get this report (though with a CMR, there’s no guaranteed release nor ETA)
Let me know which route you go.
  • June 6, 2022
Hi Mike,
Thanks for your response.
But, still I am not sure that how I can go and convince my customer to pay additional amount if you want to know your RPO, when they already purchased world class Backup tool. 😀😀
Fair enough!  It’s almost certainly possible through custom reports (which is what PS would build).
Let me see if I can get some internal folks to chime in.
  • June 7, 2022
Hi Mike,
That’s great.. This is the report exactly I am looking.
Mani
