Secondary copy schedule
  • June 14, 2022
  • 347 views
Henke
Explorer
Can I change the Secondary Copy schedule from the webconsole?
I haven’t used the webconsole very much but with deploying a new commcell I’d thought I’d look into it. I do know how to handle it from the javaconsole. Documentation didn’t give me much as it is a mix odfjavaconsole and webconsole content (confusing)
Best regards Henrik
Best answer by Collin Harper
Hello @Henke
By default all aux copies get associated to the system created aux copy schedule that is a “continuous” schedule that runs every 30 minutes. Currently there is no method of modifying it through Command Center.
Hello @Henke
Henke
Explorer
  • June 15, 2022
Thanks @Collin Harper
So in essence if we need to have a special AUX copy schedule for a PLAN we need to:
1 Dis-associate the plan from the Automatic Schedule
2 Create a new Aux Copy Schedule in the Java Console and associate with the stg copy.
3 Live with that it’s not showing in command center as having a schedule
