Tape Library Cartrige Bad Media Write Protected
  • Mar 5, 2024 2:57 PM UTC
  • 148 views
Hi there
We have Commvault 11.28.102 and have just added a tape library.
Under STORAGE\Tape I managed to add the tape, but when I go to slots I can see there that my brand new Tape is marked as Bad Media and the reason that I got is Write Protected.
Please advise.
Thank you
Best answer by SMD
Hi @Dar Ko
There will be a button on the tape, when pressed tape becomes write proected. You can release this button and try again.
Suleman
  • Mar 5, 2024 3:07 PM UTC
Hi @Dar Ko
Suleman
