transferred data for replcation job
  • Dec 26, 2023 9:55 PM UTC
  • 93 views
i have a DR site with a vmware vsphere cluster. I use commvault replication to this DR site. I would like to monitor how much date is transferred after compression and dedupe.
Where could i found this information ?
I have a LAN to LAN 10Mb/s link and i want to understand what is transferred over the WAN.
Regards
Hello @Patrick Bidondo
Replication jobs details are here in BOL:
https://documentation.commvault.com/2023e/expert/replication_01.html
For Virtual machines a replication job automatically kicks off after the backup completes and will move the deduped data to the Site B and then perform a restore of that data.
To know more details around the job you can look at the admin history and job type “replication”. This should show you application size and size transferred on network to know how much load you have going on.
Kind regards
Albert Williams
Thanks for the great question and I am sorry for the slow response on this one.
When we are talking about “replication” there are many different ways to move the data from A>B in Commvault.
Given you are talking about Dedup and compression I am guessing you are referring to Aux copy from site A to B. To know how much data was moved and written i would use the job summary report and filter on Aux copy jobs. This will give you a job by job basis on data moved.
https://documentation.commvault.com/2023e/essential/backup_job_summary_report_web_overview.html
Please advise if Aux copy is not what you are referring to and you mean true replication when we restore the data after a backup is complete.
Kind regards
Albert Williams
Hi
You’re right on your last sentence, i’m not talking about Aux Copy.
I replicate a VM once a day. As the link between my two site is low (10Mb/s), i would like to understand how replication is working and how much data can i replicate in one day. So i would like to know how much data is sent over the network to the DR site.
I understood that there is a dedupe over the WAN to be less impactfull on WAN links. Maybe i’m wrong
Thanks for your reply
Kind regards
Albert Williams
