/ws/ddb and /opt/commvault/MediaAgent64/IndexCache are not mounted anymore after the faulty SSD replacement
SSD has been replaced
Node has been rebooted once
the entry is in the /etc/fstab
Best answer by Emils
Depending on which Hyperscale you’re running (1.5 or X) these steps may differ:
https://documentation.commvault.com/v11/expert/104154_replacing_metadata_drive.html
I would high recommend reaching out to support for help if the above does not help.
