AWS EBS Direct Read API denied
  • April 13, 2021
  • 11 replies
  • 2294 views
Anthony.Hodges
Certified Expert
Forum|alt.badge.img+9
Greetings,
I have configured AWS backups under FR11.22 and the backups are running as HOTADD instead of using the new EBS Direct Read APIs.
We are using an IAM Role method on the VSA, and the following Allow EBS permissions are have been added for “Resource : *
"ebs:GetSnapshotBlock",
"ebs:ListChangedBlocks",
"ebs:ListSnapshotBlocks",
However, the follow appears in vsbkp.log.
31965 7d01 04/13 18:23:52 215259 AmazonCompute::CheckPermissions() - Action: [ebs:ListSnapshotBlocks] EvalDecision: [implicitDeny]
31965 7d01 04/13 18:23:52 215259 AmazonCompute::CheckPermissions() - Action: [ebs:GetSnapshotBlock] EvalDecision: [implicitDeny]
31965 7d01 04/13 18:23:52 215259 CAmazonInfo::CheckDirectReadPermissions() - Insufficient permissions for EBS direct read
31965 7d01 04/13 18:23:52 215259 CAmazonInfo::SelectMountMode() - Selected Mode: [HOTADD]
What am I missing ? :)
Best answer by Anthony.Hodges
Sorry, for bothering the Community. The deny reason is at the AWSOrganization SCP level.  We have to get in touch with the account master to resolve this.
Hi @Anthony.Hodges
Here are some things to check, courtesy of the Support team :wink: :
Is EBS direct API supported in the AWS region?
https://docs.aws.amazon.com/general/latest/gr/ebs-service.html
Is ec2:DescribeInstanceAttribute enabled?
There are 4 permissions needed, you have mentioned 3, please also check ec2:DescribeInstanceAttribute.
Amazon Web Services Permission Usage
Please check the permissions have been granted specifically to this AWS region.
The access node needs access to the EBS endpoints.
https://docs.aws.amazon.com/AWSEC2/latest/UserGuide/ebs-accessing-snapshot.html
Changed Block Tracking for Amazon
Stuart
Anthony.Hodges
Certified Expert
  • Certified Expert
  • April 13, 2021
Hi @Anthony.Hodges
Stuart
Yes, ap-southeast-2.
Yes.
In my testing we used Resource *, but can try narrowing to this region.
The EBS vpc interface endpoint has not been set up yet whilst doing small VM testing, but it "should" have access.
  • April 13, 2021
https://documentation.commvault.com/11.22/expert/130078_direct_read_backups_for_amazon.html
Direct read backups use the EBS service, and requires the following AWS permissions:
  • ebs:GetSnapshotBlock
  • iam:SimulatePrincipalPolicy -- Is this permission added too?
Anthony.Hodges
Certified Expert
  • Certified Expert
  • April 13, 2021
Thanks and yes "iam:SimulatePrincipalPolicy” is set too.
Couple of other things to check @Anthony.Hodges
  1. Make sure any previously configured registry/additional settings keys for this feature are removed - “bAmazonDirectReadEnabled” under “VirtualServer”
  2. Try to disable the check itself with additional setting (it seems that in some cases, API requests could be throttled and therefore giving it a false return that permissions are missing)
    Path: VirtualServer
    Type: Boolean
    Value: true
Anthony.Hodges
Certified Expert
  • Certified Expert
  • April 13, 2021
Ah, sorry I accidentally hit the answer button and I haven't tested it yet. 🤪 Perhaps, a confirmation dialog would be useful for us intermittently cross-eyed/uncoordinated people.
Thanks @Damian Andre I will try these.
@Anthony.Hodges , unmarked for you!
Anthony.Hodges
Certified Expert
  • Certified Expert
  • April 14, 2021
I have a support ticket open and it was stated that CV calls simulate-prinicipal-policy for some operations. I suspect that there are additional permissions required to call this API (Testing IAM policies with the IAM policy simulator - AWS Identity and Access Management (amazon.com), & IAM: Access the policy simulator API - AWS Identity and Access Management (amazon.com)).
For example, the simulate-principal policy gives an implicit deny to any of the permissions granted, for example S3 list all my buckets.
# aws iam simulate-principal-policy --policy-source-arn arn:aws:iam::11111111111:role/VSA-Role-Name --action-names s3:ListAllMyBuckets
    "EvaluationResults": [
            "EvalActionName": "s3:ListAllMyBuckets",
            "EvalResourceName": "*",
            "EvalDecision": "implicitDeny",
            "MatchedStatements": [],
            "MissingContextValues": [],
            "OrganizationsDecisionDetail": {
                "AllowedByOrganizations": false
CV Support provided that we can do commands like list snapshot blocks, despite the implicit deny.
# aws ebs list-snapshot-blocks --snapshot-id snap-041e89c92ab0745a3
    "Blocks": [
            "BlockIndex": 0,
            "BlockToken": "AA8BAQ96rUz...
Anthony.Hodges
Certified Expert
  • Certified Expert
  • April 14, 2021
Hi @Anthony.Hodges
No worries at all, these discussions are all valuable, showing troubleshooting steps and ideas for the Community to check and follow if anyone else sees something similar in future.
I’ll go ahead and mark your post as Best answer.
Stuart
Absolutely!  This is no bother, it’s a solid conversation and a great source of information thanks to you, @Anthony.Hodges !
