No applications were found that are eligible for Application Aware backup.Treating this as a success.
  • November 5, 2021
  • 1033 views
Hi all,
Trying to perform a Application Aware backup of a virtual server that is running a SQL instance.
Already installed the commvault agent with the following options:
  • FileSystem
  • FileSystem Core
  • SQL Server
when running a VM level backup with the option Application Aware selected, the job shows the following message:
Can anyone help sort this out?
thanks
Best answer by PALM2021
Hi @Mike Struening ,
I’ve managed to sort this out, I’ve installed the agents manually on the vms, it looks like commvault needs an additional setting in order to make this work this way.
https://documentation.commvault.com/11.21/essential/106252_reconfiguration_for_vms_that_already_use_application_agents.html
“To include virtual machines that were previously configured for application backup using an application agent such as the SQL Server agent, ensure that the following requirements are met for the application:
  • For the default subclient of the application, select Virtual Server Application Snap as the snapshot engine.
  • Specify the same server plan for the application subclient and the VSA subclient.
The application-aware workflow automatically makes these changes for existing application clients.”
Regards
Very bizarre…..those 2 are the vast majority of causes for this error.
I would suggest opening a support case then.  The ‘other’ causes I see in our incident history are all VERY specific, unique, and not easily discovered.
ps Please share the case number here so we can track it accordingly.
Happy to help!
It’s most likely either a connection issue, or the guest credentials are not right (there are other, rarer issues as well such as the SQL server not having any databases).
Can you check the following?
Those logs should give us a solid idea of what is happening.
  • November 5, 2021
Hi @Mike Struening
Thanks for your inputs.
Credentials ok, verified and reentered.
No firewall between guest, proxy and commserve
Logs won't show anything related with this behaviour.
Happy to help!
  • November 6, 2021
Regards
Glad to hear it.  Thanks for updating us!!
