Unable to attach disks to virtual machine
  • May 19, 2022
  • 711 views
I try vm restore.
restore
source : 182-ash-window
destination 184-vm-test
but
advise please
Thank you
Best answer by Laurent
Hi @chris_ahn
If you need more details you can view the vmware log of the job on the MediaAgent (or just start from the console).
But you might need to check if you have VMWare rights to perform this operation, rights to write to the target datastore, edit the machine configuration, proper zoning / rights given on the storage/SAN part.
What’s your tranport mode for the backup of this VM?
Forum|alt.badge.img+20
  • Challenger
  • May 19, 2022
Hi @chris_ahn
  • May 20, 2022
vm backup is NBD mode.
