VM Backups are running even VM was in Powered Off State
  • 10 April 2024
  • 8 replies
  • 68 views
Badge +2
Hi All,
We have many clients that are backing up even in powered off state. As per my knowledge, snapshot should be placed in the datastore and creation of snapshot consider the ESXi host rather than VM (please correct me if I'm wrong).
To avoid such scenarios, I found that we have prepared and post process scripts which can be made outside of commvault.
Can someone help me on below questions
Where I can find these scripts?
How these scripts works?
Do I need to place these scripts in every VSA?
Thanks in advance!!
Userlevel 1
Badge +5
Hi @backup ,
In order to filter the VM which is powered off to skip backup, we can configure Rules in the VM Group content so that only the VM which is powered on will get backed up.
Please refer to the documentation below:
https://documentation.commvault.com/2023e/essential/configuring_backups_for_vmware_vms.html
Badge +2
Thanks @GnanaPrakasam
I have tried as stated in the above documentation, but there is no option having Power State or On/Off while creating Client Computer Groups.
The above documentation is for 11.32, but we are in 11.28
I have gone through the documentation for 11.28 but can't find any, is this option was present in 11.28? else what is the alternate option for this
Userlevel 2
Badge +8
If you’re using the far superior CommCell Console, Virtual Machines can be filtered based on Power State at the VMware Client’s BackupSet and Subclient level.
Badge +2
Thanks @Erase4ndReuseMedia
I’m able to create the rule at Subclient level of the VCenter
Badge +2
 Hi @GnanaPrakasam , @Erase4ndReuseMedia and All,
I have configured a rule for Power state as Powered Off at vCenter Backup Set and Subclient. Even after creating the rule, powered off VM’s still getting backedup, any Idea, How it is backing up even with a rule?
Userlevel 2
Badge +8
Do you have the Virtual Machines explicitly defined as Subclient Content, or are you using Auto-Discovery Rules?
Badge +2
Yes, we have explicitly add the VMs in the Subclient content
Does this rule not applicable for predefined content?
If not, how can I exclude it from backups? Do I need to remove them manually?
Userlevel 2
Badge +8
Virtual Machines that have been explicitly added will not be filtered.
You may be able to define Virtual Machines based on their name, and have filters apply.
The Preview button should confirm / deny.
