I'm trying to wrap my head around the following. I'm setting up VM-level protection in a VMware environment and I'm using the VCD hypervisor because we want to deliver VM-level protection to our cloud customers. So I configured a vCenter hypervisor first and added the VCD hypervisor afterwards, which leverages the vCenter hypervisor. Right now there are 4 active clusters with a few others coming soon. I deployed access nodes on all clusters and they are all listed as access node. Our backup method should be hot-add, because we'll have to close down/limit connectivity between clusters because of security, so NBD will not be an option anymore. The "first" access node in the list acting as the communicator is able to communicate to all other access nodes via a network topology, no errors what so ever to be seen when it comes to the communication between the nodes.
Now when setting the transport mode to hot-add all jobs so far failed with the error that the access node cannot mount the disk, which after having a more closer look makes sense because Commvault picked the wrong access node. It (randomly) selects access nodes from remote clusters to backup VMs. This is silly of course and shouldn't be the case, because it can very easily make the correct decision which access node to pick based on information from VCD and vCenter to perform the hot-add operation.
When i change it back to auto it perform NBD backups (currently this is still possible) and sometimes it assigns the correct access node which results in a hot-add backup being created.
I'm curious to hear from other customers using VMware Cloud Director with Commvault what their experience is....
PS: If you are using the VCD plug-in then you should have a look in the software store. They just released a new plug-in with a different, more native/modern VCD look-and-feel.
