Generate report and send with email in Workflow
  • January 4, 2023
  • 278 views
Henke
Explorer
I’ve tried to create a workflow that:
  1. run a saved report
  2. sends that report in a email
I have little experiance with workflows and I haven’t been successfull in my tries. I don’t even know if it is possible to do.
Is there anyone that have done it or know how it can be accomplished?
Attached is a view of my current tries, though not successful.
Thanks for any help.
christopherlecky
Challenger
Forum|alt.badge.img+16
Post the workflow XML, and the errors you are getting.
Henke
Explorer
  • January 5, 2023
@christopherlecky I’ve attached the XML.
There is no errors, just a blank email sent.
As far as I can se the report is run but it’s not attached to the email.
Forum|alt.badge.img+2
Hello @Henke
Try calling the file under “Attachment” section as below
You can also use File Picker in the input section to load the file.
Henke
Explorer
  • January 12, 2023
Thanks for the answer @Vignesh Sekar .
Unfortunately the workflow isn’t specifically intuitive.
How would I add the path to the created report? I can’t find any attachment among the variables.
I’d like this to be a workflow without any user interaction.
Any ideas?
//Henke
Forum|alt.badge.img+8
  • February 1, 2023
how do we attach a file which is on a different machine, than the commserve?
or should this file be locally available on the commserve?
Also it didnt work when i gave the file path , it was given FileNotFound , or access related errors
