Adding nodes to existing HyperScale X
  • September 9, 2021
  • 1028 views
Marco Lachance
Explorer
Hi, I’m trying to add 3 nodes to an existing Hyperscale X cluster ?
It’s a brand new installation, the cluster is up and running in with the first 3 nodes.
Now I’m trying to add 3 more nodes, do I need to create a block with “cvavahi.py...” on those 3 new nodes as well and after that I will have the options in the Command Center to add them all under the one already there  or ?
Thank you, it’s the first time I’m adding nodes to and existing HyperScale X cluster and I don't find any documentation on this !
Best answer by Nick Maida
Hello Marco,
At this time we do not have any scripts or documentation to create a bond outside of the Data Protection and Storage Protection network. Here is a link that can help getting this configured manually.
https://www.cyberithub.com/network-bonding-teaming-in-linux/
Alternatively you can manipulate the current config files to create the new bond.
For example:
# cd /etc/sysconfig/network-scripts/
# cp ifcfg-bond1 ifcfg-bond3
# vi ifcfg-bond3
You can then edit the file “ifcfg-bond3” and edit the fields to whichever IP’s you need it to be. You can do the same process for the interface files to make the interface files a part of the new bond. This will be a lot easier than creating them from scratch.
Nick Maida
  • September 9, 2021
Thanks for your post.  Would definitely recommend checking out this documentation link which should answer most of your questions:
https://documentation.commvault.com/11.24/expert/133336_adding_nodes_to_existing_hyperscale_x_storage_pool.html
JW
Marco Lachance
Explorer
  • September 9, 2021
Thank you, it’s exactly what I was looking for ! I don't know why my search was not picking up this link !
By the way @JPW  do you know be any chance how to add an extra bond into those nodes ? We have 2 Nic card not configure yet and we need to create a Bond for DIP with specific server/clients ?
Nick Maida
  • September 9, 2021
Hello Marco,
For example:
# vi ifcfg-bond3
Nick Maida
  • September 9, 2021
How many physical network ports are available ?
Do you have spare or are you trying to create or connect to additional networks utilizing the existing bonds?
Marco Lachance
Explorer
  • September 9, 2021
@Nick Maida  It works perfectly with your how to :thumbsup:
@Damian Andre  the customer have 8 NIC per node, so at the end 4 bonds.
To access different destinations.
Thank you all.
